RCU Forums - View Single Post - CLARKE TK20 Installation and Configuration
Old 12-16-2012 | 09:31 AM
tsull's Avatar
tsull
Default RE: CLARKE TK20 Installation and Configuration
WIRING PART 1 (Custom Application)
I used a heat sink from a broken X BOX that my son had and I cut it down and mounted it for additional heat dissipation from the Super Smoker. The Super Smoker puts out a lot of heat and in the Phoenix area, heat can be a most challenging issue.......
The fuse box and 10 amp fuse is also mounted on the top rail of the KT. I have had several issues with blowing the 10 amp fuse, but I am hesitant to go with the next size up which is a 15 amp fuse. There was a Spirited discussion on another post about how fuses work.
