RCU Forums - View Single Post - CLARKE TK20 Installation and Configuration
Old 12-16-2012 | 09:53 AM
  #32
tsull's Avatar
tsull
Default RE: CLARKE TK20 Installation and Configuration
WIRING PART 1 (Custom Application)
Make certain the Servo Connectors are wired correctly.
With the plastic servo housing that has the connector tab "openings" facing up, slide each connector up and into the housing.
Make certain that you use the same wiring schema.
I use SIGNAL, POWER and NEGATIVE.
If you are wiring for a simple power run, you can still use the servo housing, but skip the first section that would normally house the SIGNAL lead and insert the POWER and then NEGATIVE lead.
By making the first servo connection "female", you can make the attaching servo connection by using the "male" ends and slide in the larger plastic housing. You can directly label these types of connections.
