RE: CDI gr8flyer55
If I program a curve to either table and save it, then reload it later, it works great. Only the copy command from table one to table two is at fault. Otherwise, I ran an engine with it today and it follows the programmed curve exactly to the degrees of the program. Don't know what else to say. I can't duplicate the timing change problem.
John
