ORIGINAL: wyo69cowboy
So who's gonna be the first to try to the Evolution tuned muffler that so wakes up the glow .60?
Using the Evo (aka Jett) tuned muffler is very tricky on a gas engine. I tested one out on the 9cc gas engine, and I had to run the engine quite a bit on the rich side too much. otherwise it would lean out when it came up on the pipe, so to speak. At the time, I needed to momentarily pinch the fuel line to get it to come up on the pipe, and even then it felt like it was still a little on the lean side. So I think one would need a in flight mixture control setup on the main needle to tweak it a little in the air to get it set just right. But the performance was pretty spectacular though, as the 9cc engine's port timing is more suited to a tuned pipe, so the performance boost was something spectacular. it really started howling like it was on a tuned pipe, up in the 15,000 RPM range.
but then the Evo 10cc has a needle bearing rod and will be less sensitive to running a little bit lean, so it might just work out Ok with it. I do have the muffler, so I'll defintely have a go at it later.
Here it is from my earlier experiments on the 9cc gas engine. So yeah it ought to be interesting on the Evo 10cc engine.
