RCU Forums - View Single Post - Battery questions for soaring model
Old 12-18-2012 | 07:22 AM
czorzella
Default RE: Battery questions for soaring model
Mark, the issue could either be related to a defective ESC or simply is incompatible with the specific motor you are using. I ran into a similar problem where a motor refused to work properly with an specific ESC, no matter what configuration I did, it simply couldn't properly and promptly start the motor as it would be expected. This ESC is still working fine with other motors.
