RE: Capiche 50
Capiche 50 e SUCCESS ! AT last....
Well..... it goes like this...
14x7 E Apc prop... drawing 45 amps on full chat... just about what I wanted, not would the prop be any good and have I solved my cut out problems...
Well, I only had two short flights yesterday 1 x 4min, then 1 x 6 min... so the answer is YES the cut out problem is sorted and must have been temperature related as I suspected... the esc is now in the cowl cheek directly in the air flow.
I will try some more manouvres today but all seems well, harriers are very effective, vertical is unlimited.... knife edge seems really noise on one side and a bit un stable, but quiet and solid the other.... I think I have too much right thrust ....
I will know better today..
I have to say though that I prefer my ic one... that is near perfect, but then it is over a lb lighter !
