RE: Capiche 50 / cutting covering material
It is possible to cut covering material in a vinyl cutter. The backer sheet is removed from the covering and applied to 2 thickness transfer sheet (sitcky side up on the backer sheet and sticky side down on the covering material). The lamination sheets should be the same size so the adhesive doesn't clog the drive dogs in the plotter.
EXCAP232
