RE: What type of glue do I use on Magnets?
<span style="background-color: rgba(255, 255, 255, 0);">Zor, I understand what you mean, and I didn't call it impractical or foolish so plz don't put words in my mouth. </span><div><span style="background-color: rgba(255, 255, 255, 0);">
</span></div><div><span style="background-color: rgba(255, 255, 255, 0);">I use pretty powerful magnets and haven't had problems with getting any of them apart, except the aforementioned Yardbird foamy that suffered damage on a landing and had the foam fail. I've never seen a magnet skinned, including countless kits, ARFs, jets and giant scale planes. I use the right size magnet for the job to begin with, so it doesn't need the 'skin' to help detachment. </span></div><div><span style="background-color: rgba(255, 255, 255, 0);">
</span></div><div><span style="background-color: rgba(255, 255, 255, 0);">It would seem to me your skin technique is only to aid in separation so that </span><span style="-webkit-tap-highlight-color: rgba(26, 26, 26, 0.292969); -webkit-composition-fill-color: rgba(175, 192, 227, 0.230469); -webkit-composition-frame-color: rgba(77, 128, 180, 0.230469); ">breakaway pull is decreased, it </span><span style="background-color: rgba(255, 255, 255, 0); ">does nothing to increase attachment to the structure as the OP originally asked. The 'skin' is attached to the structure on the outside of the magnet, so there's no increase in attachment strength. Far from being an improved technique, it reduces the maximum hold of the magnet from the start and thus would seem counterproductive. </span></div><div><span style="background-color: rgba(255, 255, 255, 0); ">If you want help with removal, I would suggest starting with the right size magnet to begin with. I too enjoy learning new things, but 'not all new things are an improvement'. </span></div><div><span style="background-color: rgba(255, 255, 255, 0); ">One thing I did to an Ultrafly Mig 29 hatch was install an extra magnet on the hatch. The fuselage foam for the metal screw was thin, so I cut a small area out and epoxied in a hard balsa block. I can screw the small wood screw out for magnet-to-metal security, or screw it in slightly an get rid of the 'clack' sound when the canopy seats and magnet hits metal. </span></div>
