RCU Forums - View Single Post - Loctite ?
Thread: Loctite ?
Old 12-21-2012 | 10:22 PM
GaryHarris's Avatar
GaryHarris
Default RE: Loctite ?
ORIGINAL: BillinIndiana
I forgot I picked up the JB Weld Perma-Lock from Menards... It's the medium strength, is it about the same thing? They didn't have Loctite.
Says it's temp resistant to 300 degrees.. Will that still work on a .42 sized engine?
Just me Bill, but I don't use thread locking goop on an engine unless I need it and so far I haven't. But I only use four strokes that have a different muffler mounting set up than two strokes. And far anything as any thread locking compound marked as "Permanent" for two stroke muffler mounting, I wouldn't use it. Steel screws going into aluminum, thermal coefficient's, not good. Your better off using an anti seize compound with the proper torque applied than using a thread locking compound.
