RE: Anylink problem with 9C
I'm basically having the same problem, but with the Heli-Max Axe 100 FP. I'm sure I put it in the alternate mode because when I held tihe left throttle to the lowest position and holding it to the left I heard the 3 beeps and then 2 beeps after that, I then removed the adaptor from the trainer port and plugged it back in and tryed to bind it with my DX6i, but the mapping was really messed up, the left throttle stick was operating the right and left cyclic and the right stick was operating the collective or throttle. I took it to my LHS and they tried to reverse it back to the default settings and they had the same problem, they thought I put it in either mode 3 or 4 and couldn't change it. <div></div><div>Any help would be much appreciated,</div><div></div><div>Macymastiff</div>
