RE: That Eureka Moment..
Thank's For that, Using the large size Cone makes starting the Laser 300 very Easy; It turns over Now using a lot less effort as you do not need to push hard on the spinner to keep contact & because the large surface area grips so well ... A spinoff of this is you will not burn the nose of the spinner no "friction" all the energy goes into the turning of the motor.. your battery will last longer too.
I'm going to make a smaller one now to fit 90-100 mm dia spinners (Just need to find a fitting that uses a smaller spot bulb) wonder were the swmbo keeps them now ![sm=47_47.gif]
