RCU Forums - View Single Post - Turbines and Winter flying
Old 12-27-2012 | 04:15 AM
colmo-RCU's Avatar
colmo-RCU
Default RE: Turbines and Winter flying
Jet A and jet A1 have a freezing point of -40 C, which is equal to -40 F, incidentally. It is required that the fuel be kept over this temp, even if antifreeze aditives are used, so non aviation kero should be around the same temperature. I wouldn't worry about the fuel freezing on you, you'll freeze first. I've never seen snow, but hopefully will as I have a flight to Toronto in Jan, hurray!!!! I must say flying out of it looks a lot of fun. Good luck
