RCU Forums - View Single Post - Sig Ryan STA
Thread: Sig Ryan STA
Old 12-29-2012 | 09:47 AM
  #773
VincentJ's Avatar
VincentJ
Default RE: Sig Ryan STA
Decided to fit the headrest to the fuselage. I wanted to get a perfect fit between the parts so let me show you how I did it. Since the top of the fuse is the contour that I am trying toreplicate then it seems onlyfitting (no pun intended) to use is a sanding block by attatching some 220 grit adhesive backed sandpaper on it. By gently sliding the headrest back and forth a few times I got a perfect fit.
What are your thoughts on whether or notI should wait until after the fuse is painted to mount the headrest or do it now before I shoot the primer?
The snow has just started to fall expecting several more inches...
ID:	1834597   Click image for larger version
ID:	1834598   Click image for larger version
ID:	1834599   Click image for larger version
ID:	1834600   Click image for larger version
