RCU Forums - View Single Post - New Griffin by Xtreme Composite
Old 12-29-2012 | 08:38 PM
  #69
Flyer88
Default RE: New Griffin by Xtreme Composite
ORIGINAL: patternflyer1
They are pretty straight forward really. I usually start with what is built into the thrust ring at the spinner and set my wing and tail incidence off of that. It's a good starting place anyway. Use good glue inside the fuse. I don't use five minute. I use west system usually, mixed most times with micro balloons. The stronger the glue joint needs to be, the less micro balloons I use. I generally sand the spot where a firewall goes lightly. Clean it well and then glue in the firewall. To do this, after figuring where it goes on the firewall, I mount the motor to the firewall. I hang the plane vertically. I use a balsa 1/16'' spacer the exact size of my spinner to space the motor away to get the alignment the same as the fuse. The spacer obviously goes in between the spinner and fuse nose ring. I put a prop ( I have one cut super short) on with the spinner and spacer. You may know all this, but maybe it helps someone who doesn't. Fire away if you have questions. Call me if you need.
Chris
Thank you for the details!
I always wondered how others did that process.
We all have our own system or method but its wonderfully eye opening to compare notes.
Thanks again.
