RCU Forums - View Single Post - Hangar 9 Meridian 10cc build thread with Evolution 10cc gasser engine
Old 12-29-2012 | 09:54 PM
flyinwalenda's Avatar
flyinwalenda
Default RE: Hangar 9 Meridian 10cc build thread with Evolution 10cc gasser engine
Next I installed the motor mounts and put threadlock on the bolts.
I also removed the nosewheel bolts and put threadlock on them and reinstalled as I'm sure these would have worked loose after a few landings.
I also drilled the hole for the throttle control tube/rod per the manual but I thought it was going to be too much of a bend to reach the carb throttle arm. My thoughts were right and I ended up changing this later on.
