RCU Forums - View Single Post - Timer troubles
Old 01-03-2013 | 01:55 PM
Bax
Default RE: Timer troubles
You need to check where the throttle stick turns the timer on and off. You set that in the section where you set what controls the timer. There should be an "ON/OFF" section after you choose J3 as the on/off control for the timer. The "ON/OFF" section controls the stick position that turns the timer on and off.
