Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
Timer troubles
Old 12-17-2012 | 07:58 PM
Default Timer troubles
T7C Tx - Timer on throttle stick. works on models 1 thru 4. added #5 & 6. setup same as 1-4. Timer only works above 1/2 throttle, stops running below that. What or where do I look for (at) to get the dang thing to work?
Old 12-26-2012 | 01:31 PM
Bax
Default RE: Timer troubles
You will have to look at the individual timer settings in those models. The timers cannot be set up the same as the other models.
Old 12-30-2012 | 10:40 AM
Hey Bax, not saying set up exactly as others. Used the same procedure, each one has different times. Set up on throttle stick to start when advanced. MODE >UP, SW>3 with pointing up. Am I overlooking something obvious?
Old 01-03-2013 | 01:55 PM
Bax
You need to check where the throttle stick turns the timer on and off. You set that in the section where you set what controls the timer. There should be an "ON/OFF" section after you choose J3 as the on/off control for the timer. The "ON/OFF" section controls the stick position that turns the timer on and off.
Old 01-05-2013 | 09:58 PM
Thanks Bax, found the missing step. All is good now!
