RCU Forums - View Single Post - Sig Ryan STA
Thread: Sig Ryan STA
Old 01-03-2013 | 05:12 PM
  #824
VincentJ's Avatar
VincentJ
Default RE: Sig Ryan STA
<u>Part4 Wheel Pant/Spat Fabrication
</u>
Last nights work was bonded to the wheel pant once again using Acetone.After drying, measurements were taken to determine where the openings within the fairing needed to goto allowthe landing gear wire to pass through.Not bonding the entire perimiter of the wheel pant proved to be a wise move as I did have to spread thehalves apart to slip the landing gear wire through. I still have to solder a bracket to the rear ofthe wheel pant where you see a small side opening. This will be to attatch the support wiresfrom the wing and fuse to the wheel minimizing lateral movement. All in all its getting there...I have an idea thatimprovesmounting therear bracket to the landing gear wire,which I will fabricate and show you tomorrow evening.
ID:	1836515   Click image for larger version
ID:	1836516   Click image for larger version
ID:	1836517   Click image for larger version
ID:	1836518   Click image for larger version
ID:	1836519   Click image for larger version
