ECU default settings for Kero
Anyone provide default settings for Kero Start on a 140 please. I changed to diesel and did not write the factory settings prior to changing over.
Have run diesel and DTE Light and going back to Kero to compare as on cool down sometimes the turbine sounds as though it has sand in it like a bad bearing. Not every cool down either. 6% DTE to Diesel.
Going to run 20 litres of kero through to see if get the same sound upon cool downs.
Turbine has been back to supplier and all is good.
