KingTech Turbines International Barry is your host and will help you with all your Kingtech questions and concerns.
ECU default settings for Kero
Old 01-03-2013 | 11:16 PM
number27's Avatar
Default ECU default settings for Kero
Anyone provide default settings for Kero Start on a 140 please. I changed to diesel and did not write the factory settings prior to changing over.
Have run diesel and DTE Light and going back to Kero to compare as on cool down sometimes the turbine sounds as though it has sand in it like a bad bearing. Not every cool down either. 6% DTE to Diesel.
Going to run 20 litres of kero through to see if get the same sound upon cool downs.
Turbine has been back to supplier and all is good.
Old 01-03-2013 | 11:45 PM
Default RE: ECU default settings for Kero
Hello
What type of battery do you use?
If you want you can found all the seeting for the K140F here
Old 01-04-2013 | 01:01 AM
number27's Avatar
a123 battery 3200mah booma rc 9.9v 3 cell
