RE: RX-18
The absolute best option is to go with a Clark TK20 board. Very few systems out there can compete from a value point and here is why<div>1. Both 75mhz and 2.4ghz Radio ready ( even am radio compliant) - Futaba compliant as well</div><div>2. Supports both battle systems either HL or Tamiya</div><div>3. Competes with the top of the line sound systems</div><div>4. Does not rely or use the RX18 which has a host of issues all of us tankers have been working to get rid of</div><div>5. BB to IR conversion is too simple if that is the way you want to go</div><div>6. Proportional ie you can move your turret 1/4" accurately and you are no longer stuck cycling through the gun elevation.</div><div>There are more reasons but if the the 6 above don't make you at least investigate a TK20</div><div>then how about the cost at $66.00</div><div></div><div>There is no system out there on the market in the world that is a better value</div><div></div><div>If you want low cost though I can sell an RC2HL radio adapter that will allow you to use your 75mhz Futaba Radio for a low cost of $45.00</div><div>it is just a Radio adapter though and does nothing to help the quirks of the RX18
Oh and Craig is right the RX18 is 27 mhz but the Futaba is 75 which was on my brain when i posted the message earlier</div><div></div><div></div><div></div>
