RCU Forums - View Single Post - using blind nuts/securing cowl
Old 01-07-2013 | 06:49 AM
BarracudaHockey's Avatar
BarracudaHockey
Default RE: using blind nuts/securing cowl
I agree that hardening the threads with thin CA will make the holes last a long time.
Here's something else you can do if you're not happy with that solution.
Take the yellow inner portion of a nyrod pushrod.
Drill out the hole so the nyrod fits snugly inside. Scuff the nyrod and expoxy it into the screw hole.
Install the cowl with self tappping screws and (here's the secret for getting screws to stay put on gassers) use rubber bonded or sealing washers on the screws. RTL Fasteners sells the bonded washers in various sizes.
ID:	1837764   Click image for larger version
ID:	1837765   Click image for larger version
ID:	1837766   Click image for larger version
