Simjet2300
Kerry
Should there be a restrictor in the lube line or is it not required in this engine. I've taken the festo off to replace and from the t piece festo to the lube festo there is obviously a very short piece of festo with no restrictor as found in other engines. I hope this makes sense as don't want too much fuel oil mix going to the bearings.
Regards
Mark
