ORIGINAL: Bax
There is a lot of incorrect information in the above posts.
If your Eclipse 7 is the one on 2.4 GHz, you'll want to use this adaptor:
TACM0008 ANYLINK CABLE SPEK DEANS MICRO US$2.99
This adaptor requires the use of a 2-cell LiFE battery pack, which is not included. It has a Deans Micro connector for the battery connection. Please see the tech notes here: http://www3.towerhobbies.com/cgi-bin...0008&search=Go
The TACM0005 is not intended to be used with the Hitec Eclipse transmitter.
Tactic equipment is not manufactured by Futaba, and is not connected with Futaba in any way.m
Thanks Bax,
My apologies for any confusion regarding Futaba connection, this was because original discussions
appeared under the Futaba support page.
Accordngly please read above references as "Hobbico Tactic"" in lieu of Futaba..
"The TACM0005 is not intended to be used with the Hitec Eclipse transmitter."
but is still listed as such on Tactic AnyLink site as pictured post #4.
(Modular 2.4GHz Eclipse (non Pro) has a 6 pin DINplug so is excluded)
Thank you for the new link, TACM0008 was not found on any Tower Hobbies or other searches prior to this a.m.
TACM0008 appears to be simply an amended
TACM005, which only this am has had some of the reference to Spektrum & Htec Tx removed, as attached.
TACM0008 permits owner to use own batteries, and is listed with the same transmitters that used to be published under TACM0005, i.e..
"This is the Tactic AnyLink SLT 2.4GHz Round Adapter Cable for use with the
Spektrum DX4e, DX5e, DX7, DX8, DX10t and DX18
and the Hitec 2.4GHz Optima 5, 2.4GHz Optima 6 Sport, & 2.4GHz Eclipse 7
Pro
Transmitters by using an optional 2S LiPo or LiFe battery.
When using the AnyLink Power Adapter, do not turn the transmitter
power switch on at any time while operating the model. This will
cause the AnyLink to stop sending signals to the Tactic receiver."
However, will now amend all own references that "TACM0008" is to be used with appropriate 2.4GHz Hitec transmitters.
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
