ORIGINAL: nalby
How many mah will the ign use? If I wanted to use an a123 1100 to power the plane and ign, with say 4-3010 servos and a Tech-Aero Ibec in a super sporster 60. how many 10 min flights would I get? Just trying to figure this out and keep the plane as light as possible.
I haven’t calculated the ignition battery drain, but on my 40 size plane, I’m used a 2100 mAh LiFe w/Tech Aero IBEC, Spektrum 8 ch RX, TM1000 Tlm module, and 4 digital Hitec 5485 servos and 1 analog 485 throttle servo. After ~60 mins of flying (6, 10 min flights), I use between 550-700 mAh. On the Meridian, I used the same setup, but with 7 digital servos and used 400 mAh for 30 mins flying. I didn’t keep track of my pit time.
Dave
