ORIGINAL: nalby
How many mah will the ign use? If I wanted to use an a123 1100 to power the plane and ign, with say 4-3010 servos and a Tech-Aero Ibec in a super sporster 60. how many 10 min flights would I get? Just trying to figure this out and keep the plane as light as possible.
I haven’t calculated the ignition battery drain, but on my 40 size plane, I’m used a 2100 mAh LiFe w/Tech Aero IBEC, Spektrum 8 ch RX, TM1000 Tlm module, and 4 digital Hitec 5485 servos and 1 analog 485 throttle servo. After ~60 mins of flying (6, 10 min flights), I use between 550-700 mAh. On the Meridian, I used the same setup, but with 7 digital servos and used 400 mAh for 30 mins flying. I didn’t keep track of my pit time.
Dave
[/quote]
That's what I wanted to hear. Thank You I usually only get 4 flights per plane when I go to the field. ( take like 3-6 planes ) so I should be good.
[/quote]
The Max battery drain on the ignition is 455mah at WOT (roughly 13,000 rpm). Typical throttle management, TO's and landings will net you about 325mah per hour on the ignition. Each airplane is different as to the servo choices, etc so you'll have to add the radio system amp draw to these numbers.
Pete
<br type="_moz" />
