RCU Forums - View Single Post - Piper Cub engine question.
Old 01-08-2013 | 09:22 AM
  #48
GerKonig
Default RE: Piper Cub engine question.
ORIGINAL: bikerbc
Well I havent flowen the Hanger 9 Cub yet but I am not overly impressed with the gear...But for 1/2 the price it is a steal...It is hard to say how it will hold up untill I actually use it...I dont care for how the rubber bands go on....I like the Robart set up better but then I am farmilliar with that and in all fairness I need to give the Hanger 9 gear a chance...For a ARF gear it is far above the norm...I would not be afraid of giving it a try...The bottom of the Hanger 9 Cub is 6 5/16'' wide which is about the same as the Sig Cub so if you want to put the gear on a Sig Cub it should fit but the BUSA Cub Fuse is about 7 1/8'' wide so it won't fit the BUSA as well....Robart makes two gears....One for the BUSA Cub and one for the Sig Cub....
Thank you for the info. I will measure mine later, but I am sure you got the right size. Will look at the gear at the Wram Show next month:-)
This is your landing gear: http://www.horizonhobby.com/products...-cub-HAN454008
Quite frankly the only powerplant for an 80" cub (if not electric) would be a 60 size gas engine: http://www.horizonhobby.com/products...ngine-EVOE10GX
Slime power is history! For slime lovers! This one is only $199.00 and the gas is (comparatively) cheap!
Gerry
