 Piper Cub engine question. >
Old 01-09-2013 | 08:24 AM
  #76
smkrcflyer's Avatar
Default RE: Piper Cub engine question.
Good information here.
http://www.rcuniverse.com/forum/m_95..._3/key_/tm.htm
Old 01-09-2013 | 11:37 AM
  #77
I also am using the HS645MG on all control serfices and a FUT standard S148 for the trottle,the system is all 6V 2700 mah.( 1/4 sig cub ).am putting in a rudder gyro in it because of the wind in WYOMING.
Old 01-09-2013 | 02:42 PM
  #78
I am going to order a Gens Ace combo ESC and 1500kv BL45a moter, 55 bucks on Hobbypartz. I havn't tried any of their stuff, but a couple of big electic guys in my club say their stuff is all good. Price is right, I believe I paid about 50 bucks to Chief Aircraft for my last Hacker 30. Hacker is top quality German I believe, but my Cub will be on floats most of the time & there is a chance of dunking. I like the idea of electric for a no engine quitting on idle plan. Anybody ever use Diamond servos? Any good? wallace.tharp
Old 01-09-2013 | 03:53 PM
  #79
You def need a little more power!!! If you hickup you have the extra thrust to get out of a jam!!!! 52 four stroke would be great!!!
Old 01-10-2013 | 12:36 AM
  #80
Dadragon could you tell me a bit about the rudder Gyro ? I know nothing about it at all...I use rudder aileron mix but I have it on a switch so I can shut it off when I choose to use my left thumb to cordinate my turns...Pllus the Cub can really help teach you how to fly properly if you let it..
Old 01-10-2013 | 04:45 PM
  #81
So I got the 4 stroke today and got it mounted tonight. Fit great without any issues. I'm a little hesitant to cut the cowling as it'll be the first time I've ever done it, was wondering if there are any tips so I can make the cut as small as possible and not mess it up.
Old 01-10-2013 | 05:16 PM
  #82
smkrcflyer's Avatar
Biggest thing is to take your time and remove small amounts. With the engine mounted in the proper location tape a piece of card stock to the fuse so that it hits the valve covers or any part that will stick out of the cowl but does not get in the way of re-mounting the cowl. Cut the card stock so that it goes over the engine with some clearance. Now remove the engine and mount the cowl. Use the card stock to draw the opening on the cowl. Remove the cowl and cut the opening but leave yourself some room so cut inside your line. Re-mount your engine and start test fitting the cowl removing small amounts at a time till you have a good fit. Do not remove the card stock from the fuse until you’re done because if you move it you will loss the alignment.
Old 01-10-2013 | 05:35 PM
  #83
yellerchamp's Avatar
My Feedback: (42)
After I make the rough cut I use the sanding wheel on the dremel tool to smooth everything, nice smooth corners, then I run the black cockpit coaming around the edge makes a nice finish look......
Old 01-10-2013 | 05:49 PM
  #84
Thanks guys, that will definitely help.
Old 01-14-2013 | 04:25 PM
  #85
ORIGINAL: smkrcflyer
I do pretty much same but I use clear plastic material vs card stock. I use a dremel also and somehow always end up cutting a much bigger hole than I need. Caution, plastic dust can be fairly toxic. Mask & eye protection required here. On my 4 strokes I try to place the muff in a position that allows installing the cowl without taking it off each time. Good luck. wallace.tharp
Old 01-14-2013 | 08:16 PM
  #86
I have the Magnum .52 four stroke in my GP fabric J-3 and it gives scale performance.Also I used Futaba S3004 servos all way round.I have a little over 800 hours in the full scale J-3 and it looks like the real thing in the air.
Old 01-17-2013 | 06:39 PM
  #87
ORIGINAL: nmav8r
Most of us R/Crs are guilty of overpowening our airplanes. My Goldberg Decathlon with a Sato 100 will hover with a 15X4 prop. In the 1/1 department, I owned a PA-16 Piper Clipper in Alaska for 7 years and flew a friend's PA-18 Super Cub with tundra tires, both out of Fairbanks, AK. As a kid my dad & I flew a PA-12 that I got soeme stick time in. Fun airplanes, can't wait to fly my Hanger 9, 40 cub on floats. wallace.tharp
