ORIGINAL: dbacque
The plans don't show the dihedral but the instructions state ''turn the wing panels upside down and move the root ribs of both panels together. With the spar at the tip rib down on the building board, block the center of each wing panel up 3/8'' of an inch.''
Yes, it says 3/8'' of an inch.
Dave
Dave,
I checked my RCM plans and the dihedral is shown (per the instructions above you posted) just above the center of the fuse top view (see attached). Are you referring to Blue Jay plans that don't show the dihedral?
David
