RE: Sweet V Assembly Thread
Glue in provided aileron servo mount and cut out to fit servo (I used 9650 for aileron as well).
Screw in provided bolts and cut to desired height. I went with 1/2" from top of wing skin which in retrospect was shorter than I would like (and there is room to go longer.)as I am only using about a 1/3 of the servo throw as a result.
Screw in all the way and then back out a turn or two so you are not interferring with the wing skin on other side.
I glued them in using rubberized CA. This seems to have worked well on the ninja.
<br type="_moz" />
