ORIGINAL: Bax
The 9C can pose a difficulty. Don't use the on/off switch of the transmitter. With the 9C transmitter turned on, unplug the AnyLink cable from the module, itself; hold the stick like you normally would, and then plug the cord back into the module. It should now configure normally.
is that a one time deal or do you have to do it each time you fly ?
I'm scared, don't want to loose another aircraft.
