RCU Forums - View Single Post - help with an accessory
Old 01-11-2013 | 01:48 PM
1QwkSport2.5r's Avatar
1QwkSport2.5r
Default RE: help with an accessory
Glow plug temp corresponds to how much methanol is in the fuel. Less methanol =
Colder plug; more methanol hotter plug. The slight exception is when using high nitro and high oil content; in this case a hotter plug is better.
I run HOT plugs up to 25% nitro. 8-25% oil. No issues here in MN.
I even use 4-stroke plugs on problem engines with high nitro without issue. I usually only use a 4C plug to diagnose a problem and swap back to a normal hot plug when it's sorted out.
