JetCat V10 ECU Rx voltage question
As I'm not getting a response from JetCat in the Direct Support Forum, I'm re-posting here hoping for better luck.
I did some searching in the JectCat V10 ECU manual and on the forums but couldn't find a definitive answer.
Can I run the V10 ECU in a high voltage Rx/servo setup, i.e. running 7.4V nominal from a 2S Lipo from the Rx into the Throttle/Aux inputs on the ECU? I would expect I can but want to make sure.
Specifically note that my question is *not* about the ECU power itself (running the 3S LiFePo as supplied by Jetcat there).
Hans.
