Reload this Page >
JetCat V10 ECU Rx voltage question
Old 01-12-2013, 09:10 AM
Gra55h0pper
Gra55h0pper's Avatar
Default JetCat V10 ECU Rx voltage question
As I'm not getting a response from JetCat in the Direct Support Forum, I'm re-posting here hoping for better luck.
I did some searching in the JectCat V10 ECU manual and on the forums but couldn't find a definitive answer.
Can I run the V10 ECU in a high voltage Rx/servo setup, i.e. running 7.4V nominal from a 2S Lipo from the Rx into the Throttle/Aux inputs on the ECU? I would expect I can but want to make sure.
Specifically note that my question is *not* about the ECU power itself (running the 3S LiFePo as supplied by Jetcat there).
Hans.
Old 01-14-2013, 02:52 AM
Dave Wilshere
Default RE: JetCat V10 ECU Rx voltage question
Hans
Yes, no problem using HV setup on the Rx (so up to 8.4v control) on a V10 ECU
regards
Dave
Old 01-15-2013, 09:27 PM
Gra55h0pper
Thanks Dave! Much appreciated!
Old 11-20-2013, 06:08 AM
lingeorge
Dave , how about the Jectcat V5.0 ECU ?, I am planing to feed the receiver & servo with 2S (7.4) for my PHT3 (HP5) , running 7.4V nominal from a 2S Lipo from the Rx into the Throttle/Aux inputs on the V5.0 ECU.
George
Old 11-20-2013, 10:00 AM
Dave Wilshere
George
Yes, every ECU from a V 4.9 is suitable for HV operation on Rx
Regards
Dave
Old 11-22-2013, 07:19 AM
lingeorge
Excellent Dave, Thanks a lot for this information!!
