RCU Forums - View Single Post - husqvarna 61 conversion
Old 01-12-2013 | 11:51 AM
Scota4570
Default RE: husqvarna 61 conversion
I used to move the sensor too. I found that often a prop hub will slip the first time you run it. I copied the idea of the fixed sensor and ring with grub screws from Ralph Cunningham. In the end it is less hassle and neater looking. Suit yourself, you are clearly a great machinist.
