RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
rebranger, what have you had go wrong with your reed valves?
armody, I like your gas can setup. So you got the hardware from Hangar 9 I see and I like the way it sits on top of the gas can. Is that thread on the gas can a common one? The Hangar 9 pump setup will work on a gas can from Home Depot or whatever?
Thanks, Ernie Misner
