RE: help with flaps!!!
Can't help you with the DX 6, but I remember having a similar problem with my 6xa. What kind of Y-harness are you using for the flap servos? Try plugging just one servo into the flap port and/or the gear port and see if it works, if it does, the problem is most likely that you need a reversing harness.
