RCU Forums - View Single Post - help with flaps!!!
Old 01-14-2013 | 01:29 PM
redbiscuits's Avatar
redbiscuits
Default RE: help with flaps!!!
You need to make aux1 (flaps) the master and slave the gear channel to it in a mix, then you can have each servo running on a seperate channel. I am assuming that you are not running retracts, correct?
Here is a link to the owners manual if you don't have one. It will tell you how to do it if your not sure, see pages 68-75. Hope this helps.
http://www.spektrumrc.com/ProdInfo/F...anual_DX6i.pdf
