RE: world models intruder
On the RCU Forums, go to classic pattern flying. At the top left, punch in the words you will research. You can do it on the whole site, before moving to single subject. Type in anything, example: [/b]World Intruder Stab Incidence[b]
Type in, World Intruder build thread. You may come up with one of mine, where it is stripped and new skins. All subjects will source the words for you, just do some experimenting. Start it up, power up, let it go, see what happens, trim from tx, make linkage or CG adjustments after a few flights. It lands great, just let it sink, add or reduce power, hit the spot.
Crank
