RE: Covering compound curves
If you have a helper it can actually be pretty easy. I use a heat gun for compound curves. If you get the covering stuck at the back like daveopam said with an iron, then get it hot with the heat gun before pulling it tight over the curve. It also helps to use tapered pieces shaped like the sections of a football to keep it from wrinkling at the small end.
