RCU Forums - View Single Post - Prolog
Thread: Prolog
Old 01-16-2013 | 01:57 PM
  #46
MTK
Default RE: Prolog
ORIGINAL: rcpattern
Matt,
It is what BJ Park called the wing shape that he is using on the Episode, which others are starting to try on the Nuance. I don't remember what the acronym stands for. I actually have a set to try as soon as it quits raining. You can see the shape in the pictures. The Episode is the best snapping plane I've ever flown, PERIOD. I think you sacrifice some things in other aspects, but the planes snap incredible,
Arch
Thanks Arch and F3AU..........
I am sure they do. Spins tooand particularly spin reversals. This planform will benefit snaps and spins of any fuselage as long as thickness was reasonable. If I were to read between the lines a bit, the amount of control required to initiate and stop the snap is minimal so exits are simple to get tracking. I didn't realize that the roots were increased to go along with the tip reduction. That effectively will bring the MAC closer to the fuse CL and that's a good thing. Reduces the moment arm. So his average root to tip ratio is likely around 3 it looks like.
That's where I had my Temptress and she was an effortless snapper at minimal control input. Now if I could only tighten the loose screw in front of those controls.....
Building them might be a pain, but the buyer doesn't do that; it's already done. They look so kool they ought sell like hotcakes
