RE: Engine mount problem
Mark, If you have to make two saw cuts (on each beam), one horizontal one vertical that intersect, don't just cut untill the two saw cuts meet. This will create a weak spot as the cuts will most likely over lap each other a little. Instead drill a hole (3/8"-1/4") where the intersection will be and carefully saw each cut to the hole leaving a nice rounded transition from each angle. File and sand smooth the area where the saw cuts were made and you will have a strong professional looking modification to your motor mount. If you don' have to remove enough material to need saw cuts, then just file the area with a half round or rat tail file, and sand smooth.
