RCU Forums - View Single Post - NEED HELP..WING TUBES...
Old 01-19-2013 | 03:16 PM
Truckracer
My Feedback: (19)
Default RE: NEED HELP..WING TUBES...
ORIGINAL: dalemilam58
I've talked around and I think I'm going to try the Sig wing joiners...and negativites for these?
They are not nearly as strong as wing tubes. You only have the strength of a few bolts and the shear strength of a glue joint for all of your spar carry though strength. I have never seen one fail but I never really trusted them. The retaining bolt tends to strip out also.
I have a big SIG Spacewalker project scheduled for next winter and I'm changing out the SIG system to wing tubes. I even find the tubes much easier to install.
Byron used the same system as SIG's for years. I did see a couple of these fail with catastrophic results.
