Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - General
 NEED HELP..WING TUBES... >
Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
Old 01-18-2013 | 07:32 AM
Default NEED HELP..WING TUBES...
OK I'm looking for a thread and I've searched for it...I need a step by step picture guide on how to install wing tubes..I've never used them and I dont have a clue on how too...also where to buy them...I just started building a Ziroli Stuka after waiting for a couple of years to get on it...I know I saw a thread with the wing tubes but i can't find it anymore...
Old 01-18-2013 | 07:42 AM
Default RE: NEED HELP..WING TUBES...
Ziroli Stukas dont require wing tubes, they are a one piece wing with a 3/4 length spar.
Old 01-18-2013 | 07:48 AM
This I know...I'm wanting to install them for ease of transportation...instead of hauling around a 100" wing I can make it about 2 40" wing halves...with the center piece attached to the fuse...
Old 01-18-2013 | 09:37 AM
My Feedback: (19)
I use T&T Landing gear as a good source of tubes and socket material.
http://www.tntlandinggear.com/
Old 01-18-2013 | 11:29 AM
My Feedback: (65)
Try this thread at RCScaleBuilder, Page 7. Will give you a good idea about making the stuka wing a three piece with wing tubes.
http://www.rcscalebuilder.com/forum/...PN=1&TPN=7
Old 01-18-2013 | 11:44 AM
thank you sir...this was the thread that I was looking for...
Old 01-18-2013 | 04:41 PM
thanks for all the help...I think I have it figured out..
Old 01-19-2013 | 05:50 AM
TomCrump's Avatar
ORIGINAL: dalemilam58
Geez, I didn't even know where to find that thread ! LOL:
This is what she looked like after Don framed her up, and I did the detailing.
Old 01-19-2013 | 08:42 AM
use the carbon tubes from taildragger not alum.
Old 01-19-2013 | 10:47 AM
I've talked around and I think I'm going to try the Sig wing joiners...and negativites for these?
Old 01-19-2013 | 03:16 PM
My Feedback: (19)
They are not nearly as strong as wing tubes. You only have the strength of a few bolts and the shear strength of a glue joint for all of your spar carry though strength. I have never seen one fail but I never really trusted them. The retaining bolt tends to strip out also.
I have a big SIG Spacewalker project scheduled for next winter and I'm changing out the SIG system to wing tubes. I even find the tubes much easier to install.
Byron used the same system as SIG's for years. I did see a couple of these fail with catastrophic results.
