RE: Spinner adapter for a dle30
You do not need an adapter. The shaft that the prop slides onto is threaded down the center. You just use the appropriate bolt through the center of the spinner, threading into the center of the stud. Very easy. When ordering your spinner from Tru turn, ask for the appropriate bolt.
