RCU Forums - View Single Post - New Evolution 10cc gas engine
Old 01-23-2013 | 03:07 PM
  #663
jspauld2
Default RE: New Evolution 10cc gas engine
I'm not sure where the 10700 on a 13x6 came from. From our numbers and the prop power calculator you get anywhere between 6-7 lbs of static thrust depending on the prop. It's up to your flying style and airframe to determine if that's adequate.
Jimmy.
ORIGINAL: fly24-7
ORIGINAL: Enterprise6
I wonder what this motor on this airframe would be like.
http://www.valuehobby.com/airplanes/...k-540-arf.html
Seems with a 13x6 I could get in to the 8lb thrust range which would be borderline 3D territory. Not sure this model has the control throws needed to be a contender.
I crammed a OS GT22 into a H-9 Katana 50 which ended up weighing 7.5 lbs AUW so you would be in the mid 6s for that model.
Based on performance feedback from others reported earlier in this thread, for a 5 lb plane, the engine can produce thrust needed for 3D. Where it might get iffy is that you'll have to probably beef up the engine box to handle the vibration which will add weight. That seems to be a common need with small 3D planes designed for glow engines.
