i stripped a 148 servo on the rudder (see my outher thread). i used the stock hardwer untill i found a kink in the rugger pushrod, i know use the stock hardwere only on the ailerons. ive also used the tail wires, but i am considering replacing them with thin-ish carbon rods with some sort of brass/ali ends, then i'll find out how to attach em[&:]
I like jonnyh am going to replace the UC for a wire one, the field opocite is freshly ploughted with 1 feet troughs and mounds
not good! ill put on an wire UC from an old panic as this will absorb the shock a bit as the UC hes departed the fus many a time!
