RE: DLE 55 problem
I still don't see the issue.
You jig drill the spinner backplate with the same drill jig as the prop, or drill a prop with the jig then drill the spinner backplate. You only have to drill the spinner once unless you dork it.
I mean, they aren't like the plastic spinners with alignment tabs, as long as you have four holes it should work.
