RE: E Flite AT-6 Texan Convert to GLOW!
Panel lines on the fuse are all done! You can't see it very well in the pic though. Next the wing. I used 1/64th chart tape. The final coat will go over that. On a 40 size model I see no reason to go with engraved panel lines, it adds weight with layers of primer. When all the panel lines are on, then I'll add the rivets, hundreds of rivets!
I think I see light at the end of the tunnel!
