Hey Cliff,
I have done this on a couple SuperStar 40.. Even tho I know one can use a single pin in front I usually use two pins in front, and two bolts in rear.. Make sure wing fits saddle as perfect as you can.. I use a hardwood block to front of wing saddle to receive wing pins and a hardwood block with blind nuts to receive rear bolts... I have a twin stix that has four bolts,two front, two rear..
If someone can tell me how to add pics to these dang post I can try to whip up a couple as I have one I am doing right now.. I already have both blocks in but have not covered fuse yet.. Wing is done and covered..
I also change them from single Aileron servo to dual servo,one per side, so I have lots of room in wing center..
Robby ( ANY plane can 3-D, )
Damage/Destroy/Disappear
